It is currently Sat Jul 19, 2025 6:23 am
PostPosted: Wed Nov 29, 2006 2:08 am
I check our sponsors and unless I missed it I see no single black fiber lines .010 thick.
PostPosted: Wed Nov 29, 2006 2:25 am
Lance, its not technically black fiber, but it may work...I found this source for fish paper. They sell it in various thicknesses (.010 being one). Fish Paper Vulcanized Fiber
$35 for a sheet may be more than you want to spend, but a 2'x3' sheet will make a lot of purfling lines.
PostPosted: Wed Nov 29, 2006 2:40 am
Lance,
I think BobC has 10 thou in stock and is expecting 20 thou soon, have a look on the home page of his site.
There ya go
Kimlarkim39050.4463541667
PostPosted: Wed Nov 29, 2006 2:43 am
Lance I have lot's of it. Let me know what you need.
PostPosted: Wed Nov 29, 2006 3:00 am
Glad that Bob has it, I only have .020 and .030.
PostPosted: Wed Nov 29, 2006 6:11 am
Does anyone have it pre-cut in strips like StewMac? I see where most have sheets and precision cutting this thin stuff is pretty tough.
PostPosted: Wed Nov 29, 2006 6:32 am
Mike, I think both Bob and I, at least, have purfling lines pre-cut into thin strips. But I do also carry double length binding height purfs to place on the side of the binding channel rather than cutting a seperate purf channel, if you get want I mean. But I do have white, black, b/w/b, b/w/b/w, maple and pearwood in small purf size pieces, like .020 to .030 x .060 x 34.5 inches
Hope that helps!
PostPosted: Wed Nov 29, 2006 2:09 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Gurian has almost anything you can think of in the purfling/binding arena. He has a $200 minimum, but if you want to build up a "stock" design for your main (spec)instruments, then buy individual "stock" for the "custom" builds, the minimum gets met pretty quickly.
Check out the web site at:
http://www.gurianinstruments.com/index.php
Hank Mauel
